spun out
Old 06-05-2006, 09:59 AM
afwfjustin's Avatar
Well when I quoted him, it was to his original statement of "Most of the time when i spin the back out it'll correct it self when i let off the gas" which just seemed odd, as letting off throttle will transfer the weight to the center of the car, instead of the rear. That's all I meant
Old 06-05-2006, 10:01 AM
mikegarrison's Avatar
Originally Posted by afwfjustin,Jun 5 2006, 09:59 AM
You must be living on another planet that does not share the same physics as Earth. When you let off the throttle, the weight is transferred to the center of the car, away from the drive wheels, thus losing traction. Braking would be even worse. When you lose traction in the rear, countersteer and apply throttle to keep the weight in the back of the car so you can regain traction and straighten yourself out.
That all depends. With mild power oversteer, breathing back off the throttle will restore grip. If you go too far with it (or lift off too abrubtly) then you will indeed keep going around.
Old 06-05-2006, 10:09 AM
darkfx's Avatar
Originally Posted by ONEQUIKSTI,Jun 5 2006, 12:56 PM
hey btw...where in Tampa do you live???
Check out the FL forum.. there is a bunch of us from Tampa and we have weekly meets
Old 06-05-2006, 12:37 PM
Hokie2000's Avatar
Wow - am I going to be the first to say:
This thread is worthless without pics of "female neighbor" that you took for a thrill ride.
Sounds interesting.....
Old 06-05-2006, 01:32 PM
SpitfireS's Avatar
Why dont you admit you did a 180 to impress your female neighbor
Look how I handle this car
Btw..
In a spin => feet in.
When in doubt => feet out.
Old 06-05-2006, 02:27 PM
RED MX5's Avatar
Not to pick nits, but letting off the throttle transfers weight from the rear of the car to the front, not the middle. Probabaly too obvious to explain, but the tires carry the weight and there aren't any middle tires. Anyway, it is the weight transferred off the back tires that reduces the available grip (regardless of where the weight goes).
Old 06-05-2006, 02:39 PM
spectacle's Avatar
Originally Posted by glagola1,Jun 5 2006, 01:10 PM
The S does not forgive.
I found this out the hard way a few days ago trying to be a dumbass with my gf in the car. Came through an onramp hot @ 72mph, throttled out exiting the ramp...yea we went for a little ride.
Old 06-05-2006, 02:41 PM
Incubus's Avatar
If you find you're going in too hot, you should go for an early apex...I read that in "Speed Secrets 2"
Old 06-05-2006, 02:53 PM
But can you explain why?
The point is that if you are too hot you will need to be braking in the corner. The more straight you are, the more you can brake.
If you take an early apex you can remain straighter in the beginning of the corner (even though you will have to turn more in the exit of the corner). So you can stay on the brakes longer and (hopefully) get slowed down enough.
If you take an early apex but don't keep on the brakes, you will just go off the road in a different place.
Old 06-05-2006, 03:41 PM
mob_blue's Avatar
careful buddy, a spin ended up costing me 8 grand to fix...insurance covering all but the deductible and most of the wear and tear items that got replaced(2 tires and brakes)
Quick Reply: spun out
