spoon brakes
Old 02-05-2007, 10:40 PM
kakahoya's Avatar
Default spoon brakes
hello!
I have few questions regarding spoon brake system.
1. can I install spoon caliper on OEM rotor?
2. if I can, does that make braking better? or is it just cosmetic?
thanks in advance.
Jay
kakahoya is offline
Old 02-05-2007, 11:01 PM
Mrkoo's Avatar
I won't think the SPOON caliper will stick with stock rotor unless you replace the bigger size of the rotor
Mrkoo is offline
Old 02-06-2007, 12:07 AM
FiLi's Avatar
Originally Posted by kakahoya,Feb 6 2007, 07:40 AM
hello!
thanks in advance.
Jay
Hi
1 - Yes, you can. I have that setup for a while. Actually i have Project MU SCR-PRO rotors with spoon calipers and Pmu pads.
2 - Yes, it will help braking, not in terms only of shorting distance, but for track use they are a lot better than OEM in every aspect, lighter from this last to. But to keep the OEM wheels, you have to put spacers.
FiLi is offline
Old 02-06-2007, 02:27 AM
kakahoya's Avatar
thanks a lot!
actually I have spoon rims so I guess I don't havee to put spacer in.
kakahoya is offline
Old 02-06-2007, 09:59 AM
FiLi's Avatar
In that case they will clear without any problem
FiLi is offline
Old 02-06-2007, 12:37 PM
Administrator
Ludedude's Avatar
Please show me the scientific measurements that prove the shorter stopping distance claim. Hell, make them unscientific even, but show me proof.
Ludedude is offline
Old 02-07-2007, 12:02 AM
FiLi's Avatar
[QUOTE=Ludedude,Feb 6 2007, 09:37 PM] Please show me the scientific measurements that prove the shorter stopping distance claim.
FiLi is offline
Old 02-07-2007, 04:03 AM
GOS2K007's Avatar
[QUOTE=FiLi,Feb 7 2007, 01:02 AM] I tested several times my setup (Spoon calipers, project MU SCR-PRO rotors and Ferodo DS3000 pads) agains the OEM setup on
GOS2K007 is offline
Old 02-07-2007, 04:41 AM
dagostino777's Avatar
are spacers required for the oem AP2 rims as well... If so.. How much do i need?
dagostino777 is offline
Old 02-07-2007, 05:00 AM
DerrS2K's Avatar
I believe it is 15 to 20mm spacer
DerrS2K is offline
Quick Reply: spoon brakes
