SpeedCraft Turbo intake
Hey guys i was looking at the pictures from chris and is it me or that intake is too close to the engine. Look at it it looks like theres going to be hot air going in.
Again, it's intercooled. No point in ram air. Also, if you'll look at the pictures, you'll see there aren't alot of options because the space between the motor and that wall to the left (as you're viewing the car from the front) isn't very big. And there is a heat shield on the turbo.
Excuse my ignorance here....an intercooler cools the intake temperature down. If your intake is taking in hot air(100 degrees), the intercooler cools it down X degree's. If your intake takes in cooler air(CAI, 90 degrees), & your intercooler cools it down the same X degree's, wouldn't this be even better?
It probably wouldn't be a noticable difference, as the (breaks out calculus knowledge) temperature decreases, it decreases less per amount of time, with it cooling down slower as it gets closer to the outside air temperature. I believe the graph looks similar to 1/x. From what I hear, the intercooler gets the air pretty close to outside temperature, so it wouldn't be noticable if the intake temperature was actually cooler to begin with. The only way to really notice a difference is if you could keep the air from heating up between the intercooler and throttlebody.
i have to agree with s2kfanatic theres a reason why every turbo setup out there got the intake away from the engine. why take hot air while u can take colder air. My mechanics has seen pics from the setup and they very impressed besides the intake. they all say the same, is common sence to keep it away from the engine. actually they said that is taking in the same temperature as the stock intake, cause is taking hotter air and is been intercooled to the stock temperature, but if you put it away from the engine with a heatshield. and slap a intercooler then u getting performance gains with colder air.
Until someone measures the actual temperature leaving the intercooler this is all moot. If the intercooler actually does bring intake air temperatures down to near ambient then it really would be useless to tack on more hardware to reduce temps any further.
Anyone know any good intercooler information sites?
Temin
Temin
