Soft top replacement
Old 05-08-2006 | 12:38 PM
RaceyR6's Avatar
Default Soft top replacement
I have a 2001. Does it matter which glass softtop year I get? Will 03-06 glass softtops all fit onto the 01 frame? Thank you.
Old 05-08-2006 | 01:54 PM
fmah's Avatar
I have a '01. Just put a '06 top on. The only difference is that you have to round up the parts yourself to wire up the defroster. The mechanical parts (top, catches, side catcher) are the same. The '01 kit is no longer available and just has the defroster relay, switch parts, and harness (under console). PM me if you want detailed information on wiring up the top (you need some basic wiring skills).
Old 05-08-2006 | 03:09 PM
Hockey's Avatar
You'll need to modify the frame with additional straps to ensure it folds correctly to accomodate the glass. If you have the two snaps in the back tray for the tonneau cover, those will need to be removed as well to clear the glass.
-Hockey
jon604
09-07-2015 10:53 AM
ASOC
06-28-2015 01:56 PM
aris
Αμάξωμα - Κουκούλα - Εσωτερικό
71
10-02-2008 01:49 AM
thepol911343
03-01-2007 09:14 PM
S2K DRIFTER
03-10-2006 09:49 PM
Quick Reply: Soft top replacement
