Snorkel Setup: Cutting Vs. Removing Air Guide
i know theres plenty of "how to" guides on snorkel installations but one thing im still unclear of is whether or not it would be ok to fully remove the plastic air guide. ive seen setups where people cut a portion out of the air guide just big enough to fit the snorkel in whereas ive seen others completely remove the airguide thus creating a gap. so which method would be best? what are the pros and cons to leaving it on with a cut versus taking it off completely?
on another note, ive read that ap2's have a bar somewhere within the bumper that gets in the way of the snorkel. does anyone have pictures or advice as to how to fix that situation?
THANKS for helping this s2 newbie out
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
![biggrin.gif](https://www.s2ki.com/forums/images/smilies/biggrin.gif)
The general concensus is that the air guid eis there for a reason, and when i installed mine i remember doing a search which pull up threads explaining why.
I would definately cut the air guide to fit for install - or if you have a rad cooling plate you can just remove it completely. I would not just remove it and leave the area open though.
YMMV
YMMV
YMMV
YMMV
thanks again!
Originally Posted by WPS,Feb 26 2006, 10:11 PM
cut the inlet to fit. two bolts holding the reinforcement bar on each end. remove the 1 bolt closer to engine on both end. rotate bar for clearance. it'll fit
anyways, to reach the bolts on the bar, do you have to take bumper completely off or can they be reached through the front grill? i assume all 4 bolts need to come off first before rotating the bar. then upon placing them back in, just put in 3? plus what tool is needed to take the bolt off. i just moved so im without tools
![frown.gif](https://www.s2ki.com/forums/images/smilies/frown.gif)
any pictures would be appreciated. thanks!
[QUOTE=mooshy_sushi,Feb 27 2006, 01:34 AM] ahh, what perfect timing! i was reading through old threads and saw your method in one of them. i actually was about to pm you, haha.
I just installed mine this weekend. It took about a half hour. I removed the air guide. I'm looking for a Carbon Kevlar rad cooling plate to match the spoon intake. The only one i have seen doesn't have the hole for the intake...
I think it would look better to just paint the CF rad cooling plate a flat black. The two different CF don't match. What are other people doing?
![](http://www.kidimports.com/item_pics/CF-930032_24.jpg)
CARBON KEVLAR Link
How easy is it to cut CF without fraying the edges?
CARBON KEVLAR Link
