Slight Rubbing From Rear Tires
Hello,
Recently got new tires that are 255/40/17 and minor rolled my rear fenders but getting a slight rub only on my rear drivers side. Also dropped 1 inch from coils. I haven't gotten an alignment yet, is that the cause?
Thank you
Thank you
You can increase your camber when you get it aligned to correct the clearance issue but you will have increased tire wear, hopefully just needs a standard alignment to correct the rubbing.
