Slight bucking/missing during cruising
Occasionally while just driving the car will buck a little bit. It feels like its missing but I could be wrong. Under acceleration and deceleration it doesn't do it.
Car had Denso Iridium plugs put in a few thousand miles ago, thats all I know since I just bought it.
any ideas/suggestions?
Thanks
SimpleMan
Thanks
SimpleMan
For starters, missing occurs under acceleration too, so it's not that. What Gear/Speed/RPM? If you want better guesses, supply more information.
Also are you getting a CEL? True missing could through a code. Though this could be anything from lugging to bad gas.
Check this out. Maybe it will help. Im having the same problem as well as a few others in this thread.
https://www.s2ki.com/forums/index.php?showtopic=478799
That's not enough info... What speed/RPM/Gear??? Does it get better or worse with higher speed? What's the milage? Have you every had the fuel filter changed? Do you feel the symptom in the seat or the steering wheel?
