Simple Question
Simple Question
hey guys, just a quick question does your (all s2ks) come with all the little plastic clips that hold the front fender lining in? Those little plastic things in the wheel-well?
I noticed rubbing on my front tire and looked around and found that 2 of those little plastic things are gone (I replaced them after buying the car used, thinking it could possibly come stock without it.)
Anyway just curious as to who else has these in or has come across the same problem and found a solution. Im thinking just a normal black screw, washer and bolt since there is a place to put it.
Thanks
Thanks
38 cents from the dealer if I remember correctly. Might be 1.38 and there are between 28 and 32 to a lining. Gets quite expensive for such a small piece of plastic.
