short ram vs. cold air intake
#21
I had AEM v2 for 2 yrs, loved the sound and the few horses it gave. I got a vented hood this year so I went back to stock in fear of hydrolock. Man, I miss the sound and throttle response. In desparation, I gutted the stock box...wholala, gutted stock box actually sounds and feels similar to AEM, not exactly, but close. So until I 'feel' justified to spend more on a high end intake like J's, I am gonna keep the stock box, perhaps replace with K&N filter.
By the way, short intake doesn't make sense at all because of heat soak, unless for track use with vented hood.
#22
Originally Posted by hygiene boy,May 25 2004, 02:52 AM
I have read this too however have not seen any dyno runs to substantiate the claimed power loss. I have installed a few bypass valves and it's basically multiple rubber check valves covered with foam and I don't see how this could transfer any more heat than a metal intake. The valve cannot open by design unless the filter end of the intake is submerged in water.
it's a thing that sit in between two smooth flowing tube with some weird shaped ribbs and foam, the two rubber pieces don't always close seal neither. i had one before. one of the explanation of why it will take away power=the valve disrupt the flow of the air
the reason you will not see alot of gain for intake is partly because honda putted out such a good design on the head flow and stock intake.(and partly because it's a tiny small displacement motor) You will not see a 20 hp gain on a ls1 with a 100 dollar intake.
#23
Originally Posted by tenblade2001,May 24 2004, 06:50 PM
1) no hydrock issues with comptech
2) K&N isn't that good of filter. Check out some of the post by Road Rage. The K&N filter lets in a lot of garbage.
yummyph0916
10-30-2004 12:54 PM
