shifting versus granny shifting
#33
Why would rev-matching (heel-toeing) damage or wear more than granny shifting? I think its the other way around if done properly. Less clutch friction, less tranny stress and less diff stress.
I dunno where u got the idea..
#34
Originally Posted by Hyper-X,Jul 24 2004, 02:56 AM
Don't even concern yourself with double clutching if you can't H&T. The reasoning behind double clutching was that older cars didn't have syncromesh gears to help them slide into each gear.
a search will bring up all sorts of opinions on this
#35
#36
#37
Originally Posted by thereisnospoon,Jul 24 2004, 05:57 AM
exactly - you are putting less stress on any driveline component during downshifts although you are clutching twice as much - so maybe you are accellerating the throw-out bearing wear...
noticed that sometimes double-clutching provides the smoothest transition into gear. the car is ALIVE!!!!
i couldn't imagine ever having to rev match on an upshift. i believe alot of the shifting is intuitive by listening and feeling the transmission and clutch respectively.
I wanted to get the terminology straight so that i can talk about my driving.
Does holding the clutch down wear it out alot? I guess it does. I probably could
find the answer to this one. For example if your at a stop light and holding the clutch in. Its probably better to put my foot on the restpad and when the light turns green put in the clutch and give it gas and go. If im really lazy at a light I will pull the e-brake and let my feet rest. i have been catching myself at stop lights lately with the clutch pushed all the way in. every time i pull my foot off and put it on the rest pad. Its a bad habit right?
#39
IIRC, keeping the clutch engaged (i.e. depressed) wears out the throwout bearing. If you're waiting at a long light, it's best to put the car in neutral instead of standing on the clutch the whole time.
