Service Bulletin:Differential Fluid
Old 12-28-2001, 02:28 PM
unregistered's Avatar
Default Service Bulletin:Differential Fluid
I was at my dealer yesterday and asked to purchase differential fluid and was handed SAE 80W-90 Honda gear oil. I was also told that a SERVICE BULLETIN (Honda Canada) had been issued to the effect that this is the ONLY fluid to be used in the diff which shall not void the warranty.
Anyone else hear of this and if so can you get a copy to scan and post for the interested parties (everyone reading this) ?
Pierre
Old 12-28-2001, 02:38 PM
Banned
Tugz_S2K's Avatar
Possibly true....there may be special additives or friction moddifiers in the oil to help with the functioning and operation of the Torsen rear end. Thats my guess.
Old 12-28-2001, 05:09 PM
cdelena's Avatar
Would be nice to see the bulletin. All the documentation I have seen simply calls for a GL5 or GL6 lubricant with no mention of a Honda product. Very different from the transmission that specifies the Honda fluid. They could hardly void the warranty for following the owners manual.
Old 12-28-2001, 05:31 PM
Administrator
cthree's Avatar
Agreed. Could you have your dealer make a photocopy of the TSB or fax it to 760-738-1115. Fax is best since I wouldn't need to scan it. I'll add it to the library.
Old 12-28-2001, 05:42 PM
Sideways's Avatar
When I changed mine the dealer only had bulk and told me to go to the parts house and get diff fluid. When it drained, it was very gray and moly like in appearance. The new is clear amber.
Old 12-28-2001, 05:44 PM
xviper's Avatar
I just hate it when some little mealy mouth Napolean at the dealership starts to quote "this" and "that" and use scare tactics like this. It's like they're lecturing little children or something. Go back and get a copy of the bulletin. Tell him to put up or shut up. If he gives you a copy, then we can all take it to our lawyers when the time comes. (Woodwork, where are you?) If the dealerships have their way, we would use nothing but Honda air filters, oil filters, coolant, oil, grease (how many here are "sold" on Shin Etsu (sp?) grease for the seals ), hinge & lock lubes. Hell, maybe we should be putting only official Honda air into our tires. Anybody been scared into buying your tires only through the dealer? Geez, Louise!
Old 12-29-2001, 01:15 AM
Former Sponsor
ReedZ's Avatar
Hmmm, not listed here (http://www.nhtsa.org/) yet. Maybe its a new issue.
We need bulletin dates and numbers! All dealers lie!!
Search for records on
Year: 2000
Make: HONDA
Model: S2000
Technical Service Bulletins
Make: HONDA Model: S2000 Year: 2000
Service Bulletin Number: 000101 Bulletin Sequence Number: 103 Date of Bulletin: 01/00
NHTSA Item Number: SB610337
Component: INTERIOR SYSTEMS:SEAT AND SHOULDER BELTS AND BELT ANCHOR:OTHER PARTS
Summary:
INFORMATION ON REPLACING THE SEAT BELT TENSIONERS. *TT
Service Bulletin Number: 00037 Bulletin Sequence Number: 125 Date of Bulletin: 04/00
NHTSA Item Number: SB612554
Component: VISUAL SYSTEMS
Summary:
VEHICLES MAY EXPERIENCED THE REAR WINDOW THAT IS CREASED, CLOUDED, OR SCRATCHED. *MJS
Service Bulletin Number: 00054 Bulletin Sequence Number: 156 Date of Bulletin: 12/00
NHTSA Item Number: SB615716
Component: POWER TRAIN:TRANSMISSION:UNKNOWN TYPE
Summary:
WHILE DECELERATING IN 3RD OR 2ND GEAR, A BUZZING OR RATTLING COMES FROM THE ENGINE OR TRANSMISSION BETWEEN 4,000 AND 3,000 RPM. *TT
Service Bulletin Number: 00054 Bulletin Sequence Number: 199 Date of Bulletin: 03/01
NHTSA Item Number: SB619919
Summary:
EXPERIENCING A BUZZ OR RATTLE FROM THE ENGINE OR TRANSMISSION WHILE DECELERATING. *TT
Service Bulletin Number: 00078 Bulletin Sequence Number: 189 Date of Bulletin: 10/00
NHTSA Item Number: SB618934
Component: INTERIOR SYSTEMS:ACTIVE RESTRAINTS:BELT RETRACTORS
Summary:
PRELIMINARY SERVICE BULLETIN REGARDING SAFETY RECALL - S2000 SEAT BELT RETRACTORS. *TT
Service Bulletin Number: 00083 Bulletin Sequence Number: 199 Date of Bulletin: 10/00
NHTSA Item Number: SB619954
Component: AIR CONDITIONER
Summary:
THIS BULLETIN STATES THAT IN HUMID CONDITIONS, WITH THE A/C ON AND THE FAN RUNNING AT MAXIMUM SPEED, WATER DRIPS ON THE PASSENGER'S CARPET. *TT
Service Bulletin Number: 010200 Bulletin Sequence Number: 189 Date of Bulletin: 02/00
NHTSA Item Number: SB618951
Component: ENGINE COOLING SYSTEM:OTHER PARTS
Summary:
BRIEF INFORMATION ON DIAGNOSING ENGINE COOLANT TEMPERATURE SENSORS AND TEMPERATURE GAUGES. *TT
NHTSA Item Number: SB618955
Component: ENGINE
Summary:
INFORMATION ON THE S2000 ENGINE AND OIL CONSUMPTION. *TT
NHTSA Item Number: SB618958
Component: ENGINE
Summary:
INFORMATION ON HONING FIBER REINFORCED METAL (FRM) CYLINDERS. *TT
NHTSA Item Number: SB618959
Component: POWER TRAIN:TRANSMISSION:AUTOMATIC:CONTROL MODULE (TCM, PCM)
Summary:
BRIEF INFORMATION USED WHEN ORDERING PARTS FOR SERVICE BULLETIN 00-055 - GRINDS WHEN SHIFTING INTO 2ND GEAR. *TT
Service Bulletin Number: 01038 Bulletin Sequence Number: 199 Date of Bulletin: 03/01
NHTSA Item Number: SB619927
Component: STRUCTURE:BODY ROOF:CONVERTIBLE TOP
Summary:
ON CERTAIN VEHICLES, THE REAR PART OF THE CONVERTIBLE TOP COVER DOES NOT STAY TUCKED IN. *TT
Service Bulletin Number: 010400 Bulletin Sequence Number: 189 Date of Bulletin: 04/00
NHTSA Item Number: SB618982
Component: AIR CONDITIONER:COMPRESSOR
Summary:
SUBJECT REGARDING A/C COMPRESSOR MOUNTING BOLT TORQUE. *TT
NHTSA Item Number: SB618992
Component: INTERIOR SYSTEMS:INSTRUMENT PANEL:GAUGE:INDICATOR
Summary:
INFORMATION ON RESETTING THE MAINTENANCE REQUIRED INDICATOR. *TT
NHTSA Item Number: SB618997
Component: MANUFACTURERS INFORMATION TO DEALERS
Summary:
INFORMATION ON THE SERVICE MANUAL INDEX. *TT
Service Bulletin Number: 010999 Bulletin Sequence Number: 800 Date of Bulletin: 09/99
NHTSA Item Number: SB608007
Summary:
INFORMATION ON NEW S2000 ROADSTER. *TT
Service Bulletin Number: 011000 Bulletin Sequence Number: 189 Date of Bulletin: 10/00
NHTSA Item Number: SB618933
Summary:
LETTER TO SERVICE MANAGER REGARDING SAFETY RECALL 00-078 - S2000 SEAT BELT RETRACTORS. *TT
NHTSA Item Number: SB618968
Summary:
INFORMATION ON REPLACING VINYL REAR WINDOW. *TT
Service Bulletin Number: 031000 Bulletin Sequence Number: 189 Date of Bulletin: 10/00
NHTSA Item Number: SB618929
Summary:
SUBJECT REGARDING RECALL ANNOUNCEMENT AND STOP SALE ORDER FOR 2000 MODEL YEAR VEHICLES EXHIBITING THE SEAT BELT RETRACTOR THAT MAY OCCASIONALLY LOCK UP WITH THE BELT FULLY RETRACTED. *TT
Service Bulletin Number: 171100 Bulletin Sequence Number: 157 Date of Bulletin: 11/00
NHTSA Item Number: SB615764
Summary:
INFORMATION REGARDING MISPACKAGED SEAT BELT RETRACTORS. *TT
Service Bulletin Number: 181000 Bulletin Sequence Number: 188 Date of Bulletin: 10/00
NHTSA Item Number: SB618917
Summary:
SUBJECT REGARDING SEAT BELT RETRACTOR RECALL UPDATE. *TT
Old 12-30-2001, 05:44 PM
OK,OK!
Since I brought this friggen subject up, and as I have no reason to disbelieve the clerk at the parts counter (he being a SOLO 2 compatriot and all), I shall obtain from this dealer, or another one around town, the bulletin in question, if it exists in Canada, in the next few working days or my name isn't Paul, er John, er Simon....., na er ya well.....
....... Pierre
N.B. .........trust me........
Old 12-30-2001, 08:02 PM
jschmidt's Avatar
[QUOTE]Originally posted by xviper
[B]I just hate it when some little mealy mouth Napolean... Hell, maybe we should be putting only official Honda air into our tires.
Old 12-31-2001, 04:46 AM
VisualEchos's Avatar
Originally posted by jschmidt
Hot Button?
Probably, haha. When he used to own a Viper the dealer probably told him that the oil was some special blend only available through them @ $400 bones a quart, and if he decided to use some other oil it would not only void his warrantee, but be terminal...lol.
Kidding
Andrew
Quick Reply: Service Bulletin:Differential Fluid
