Self Oil Change
Old 10-05-2007, 08:39 AM
nightcrawler7188's Avatar
jack it up from the right side front (where hk s2k showed you), open the drain bolt, let most of the oil drain out, remove the filter, let most of that drain out, then lower the car down and let it sit level for 5 minutes or so. then proceed to replace with new filter and close the drain bolt and refill with new oil.
simple
Old 10-05-2007, 08:55 AM
hirev's Avatar
rino ramps, costco oil by chevron,honda filter and washer, done deal. every 4,000 or so.
Old 10-05-2007, 09:02 AM
rocrfella's Avatar
Originally Posted by 00CivicSi,Oct 5 2007, 02:27 AM
I think YOU are getting the jack points mixed up.
From the shop manual (There's a better version out there, but I couldn't find it this morning):
That was where he was pointing at. One on each side behind the front wheels and one on each side infront of the rear wheels.
Old 10-05-2007, 09:06 AM
SSSnakeSSS's Avatar
simple
Now that is great advice, just a couple of jacks and you got it done. Sometimes the simple processes are missed.
Nice, you just solved my reaching problem.
Old 10-05-2007, 09:16 AM
S2kracka's Avatar
I use ramps. Drive on, drive off, easy
Old 10-05-2007, 09:30 AM
deathsled's Avatar
Oil change is a breeze especially if you have a CAI.
I roll the front wheels up on two 2x4s I lay in my driveway, pop my hood, slide my oil drain container under the car, undo the plug and filter by reaching down from above, and a few minutes later I'm done.
Old 10-05-2007, 12:48 PM
CitadelBlue's Avatar
No need for ramps or jacks ..... All you need is two (2) each 2x6x8 inch blocks of wood that are cut on one side at a 45 degree angel to allow the front of the car to drive on. This extra height is sufficient for my oil drain pan to slide under the car. After that , everyting is done from the top - oil drain plug and filter removal, installation etc ....
Old 10-05-2007, 12:52 PM
00CivicSi's Avatar
Right, and I was pointing out that there were TWO MORE jack points, ONE of which was the one the OP was referring to when he said that his jack didn't reach (and is shown on the right hand side of the picture from the shop manual that I linked to).
You deleted the most pertinent part of my post that you quoted.
Originally Posted by 00CivicSi @ Oct 5 2007, 02:27 AM
There are six total. In addition to the two (on each side) that you show, there are two central jack points: one on a cross-member just in front of the engine for lifting the front of the car, and the bottom of the differential serves as the rear jackpoint used to lift the rear of the car.
...which was in response to hk_s2k pointing out ONLY the side jack points...
...which was in response to the OP making the statement...
Originally Posted by hipopkboy @ Oct 5 2007, 05:52 AM
the front jacking point is too far in and my floor jack wont reach it,
People here really need to work on their reading comprehension!
Old 10-05-2007, 12:56 PM
deathsled's Avatar
now thats just going all out. No need to have a 45 degree slope on the front of the boards. If you can't slowly drive your car up on to two blocks of wood you've got issues
Old 10-05-2007, 01:02 PM
MikeyCB's Avatar
Originally Posted by 00CivicSi,Oct 5 2007, 02:52 PM
Right, and I was pointing out that there were TWO MORE jack points, ONE of which was the one the OP was referring to when he said that his jack didn't reach.
You deleted the most pertinent part of my post from the quote.
Please keep up!
Though neither of those extra two pointed out are relevant for oil change procedure? YOU keep up We could teach him how to use spring compressors too, but it won't help him change the oil!
Sorry, couldn't let you slide on that!
Quick Reply: Self Oil Change
