Sad Day!!! Can't Lower My S :(
Old 06-09-2003 | 10:10 PM
Kodokan_4's Avatar
I spent the better part of the day calculating and looking at all of the available set-ups to lower my car. After the work was done I went out to figure out if the drop will be okay to get in the driveway at my house.
I guess I should have done things the other way around! The following pics were taken with OEM tires and suspension. Obviously, I need more clearance than I had anticipated:
-Pete
Old 06-09-2003 | 10:17 PM
Strike's Avatar
Is that straight in or at an angle?
Old 06-09-2003 | 10:18 PM
sebrings2k's Avatar
that sucks dood....
Old 06-09-2003 | 10:20 PM
s2k_9000rpm's Avatar
what springs did you use to drop your car? it looks as if its sitting really low. any pics from the side to see how the car sits?
Old 06-09-2003 | 10:24 PM
J.T's Avatar
J.T
For a minute I thought that's how the car sat on a level surface. I just laughed....sorry.
Can you go out that driveway at anykind of an angle?
Old 06-09-2003 | 10:29 PM
wicky's Avatar
Pete, you need to move. That is all. I can make my driveway with dr21's with about 1" clearance at both ends......
Old 06-09-2003 | 10:41 PM
exzeltus's Avatar
Originally posted by Kodokan_4
tthat looks like a shark staring at me. I love that shot.
Looks like its time to pour some cement mix.
DJ Qube's Avatar
Airbag suspension
Old 06-09-2003 | 10:43 PM
Kodokan_4's Avatar
This is as much of an angle as I can get. Today the most clearance I could get, using the angle technique was less than .75"
I could use some adjustable spring perches, and just lower about .5" but it will still be difficult not to scrape it. I'd really like to drop it 1".
It's really hard for me to think about moving. I've got a pretty nice place, and the rent is only $280/mo! How do you think I can afford my mods!!
This SUCKS!!!
-Pete
Old 06-09-2003 | 10:50 PM
docofmind's Avatar
Pete, if you remember, i pulled into your parking spot with only minor scraping. Really minor. 2 thing, my car is lowered a lot on stock tires and they were extremely bald
Remember, as long as you go slow and approach at an angle, you are good to go. Even if the bottom gets scratched you can never see it anyhow. The oem lip is pretty damn well built.
Quick Reply: Sad Day!!! Can't Lower My S :(
