S2k air conditioning
#21
Anybody else's blower motor chirping on them? At full blast the airflow will be too loud to hear it, and at 1-2 bars it won't show up, but at about mid-power there is a definate chirp from the blower motor.
#22
Originally Posted by landfighter,May 23 2005, 08:06 PM
My a/c also works VERY well. I run with 3-bars on inside air/4-bars outside air for air volume, but turn the temperature dial slightly toward the warm side.With the temperature on max and fan around half, it gets so cold my hands start to hurt.(and no...I don't have arthritis )
p.s this is in 100+ temps.
#23
Is it possible that you might have some leaf litter in the blower housing? I've had that problem on other cars before and I made a kind of chirping sound.
Just a thought!
Drive Safe,
Steve R.
#25
Originally Posted by Silver9k,May 25 2005, 12:58 AM
Is it hard to recharge the system with freon yourself?
You can buy a cheap recharge kit that's just got a single tube that connects the can of freon to the low pressure side of the AC system. The problem is, you really need a full gauge set that lets you know what the pressure on the low and high pressure sides are doing. It is possible to over charge the system and it won't work any better under that situation than it will if it's under charged.
Drive Safe,
Steve R.
#26
Originally Posted by Intrepid175,May 25 2005, 07:29 AM
This is not intended as a smart-a$$ reply but , not if you have the right tools and any idea of what you're doing.
Drive Safe,
Steve R.
Drive Safe,
Steve R.
#27
Drive Safe,
Steve R.
Drive Safe,
Steve R.
haha, jk
Ya, I was asking cause I've seen that stuff for sale or at least the R-134 or whatever it is...I was just wondering if it would be hard to do myself...and well, thanks...I guess I don't want to do it it's normally around $200 to get the system "recharged" by a dealer isn't it?
#28
No need to go to a dealer, a good shade-tree mechanic can do it for a 6-pack and the price of refrigerant. It's not a difficult procedure, it's just there's a lot of very expensive equipment that can be damaged with an over/underfill. Luckily, nowadays, the compressor won't run when it's tooo low on freon. As long as the system is still pressurized at least some all you need to do is top it off (provided the leak is small enough), but if air gets into the system, you'll need to have it professionally repaired because they have to replace the dryer and vacuum out the system.
#29
My S A/C cycles also. I never really thought about it tho since the A/C on my RSX did the same thing. My gf's Prelude's A/C (tho it may be cycling) is not as apparent (I don't really notice it). Perhaps the newer A/Cs do this.
