s2000 gear (MAX SPEED)
Originally Posted by mxt_77,Jul 27 2004, 03:49 PM
OK... so who's going to be the first person to go out and verify this?
I've done about 15 in reverse in my S. I've done a little over 30 mph in reverse in my CRV. The CRV is very solid going in reverse at that speed.
Originally Posted by RACER,Jul 27 2004, 05:59 PM
This is what my car will do at 9k (red bars flashing in 1st, 2nd, 3rd, 4th, and 5th gears)
First: 39 mph
Second: 60 mph
Third: 89 mph
Fourth: 112-113 mph
Fifth: 139 mph
This is with red bars flashing for about 2-3/10th's of a second before shifting. The red bars were flashing in fifth for about one-two second(s) before I shifted into sixth gear.
First: 39 mph
Second: 60 mph
Third: 89 mph
Fourth: 112-113 mph
Fifth: 139 mph
Originally Posted by PMantis24,Mar 12 2004, 01:50 PM
2000-2003 @ 8900rpm
1st - 44.17
2nd - 67.67
3rd - 93.44
4th - 119.20
5th - 142.52
6th - 170.64
2004 @ 8000rpm
1st - 37.91
2nd - 58.08
3rd - 80.19
4th - 102.30
5th - 126.08
6th - 155.66
Don't expect to hit 170mph
1st - 44.17
2nd - 67.67
3rd - 93.44
4th - 119.20
5th - 142.52
6th - 170.64
2004 @ 8000rpm
1st - 37.91
2nd - 58.08
3rd - 80.19
4th - 102.30
5th - 126.08
6th - 155.66
Someone said our cars only top out at 147mph but I guess that all depends if you've changed your gears or not.
Originally Posted by gernby,Jul 27 2004, 04:14 PM
You can't consider these accurate for 2 reasons. First, you would have to bounce the rev limitter for at least a second for the speedometer to update itself to the correct speed (especially in the lower gears). For example, in 1st gear, the difference between 39 and 42 MPH is way probably 1/10th of a second, and the speedo doesn't update that fast. Second, neither the tachometer or the speedo are accurate.
Originally Posted by TunedS2000,Jul 27 2004, 09:30 PM
I thought the 04 had a higher top speed because I was told 6th gear was lower... am I wrong?
