RS*R Invidia Exhaust Installed
I was going to drop this into the Invidia GB thread but it is closed so here we go.
The weather FINALLY went above 0C today so I took advantage of the opprotunity and decided to install my exhaust.
Jacked Brat up onto 4 jack stands...
I was lucky, my cat bolts were not corroded on so they came off easily. I sprayed WD40 on the rubber hangers and they slide off easily also. Out with the old...
In with the new ...
FINISHED
This exhaust sound absolutely incredible! I have only started the car in the garage but can't wait to get it on the road!
In with the new ...
FINISHED
Where you having any problems with the driverside canister being higher than the passanger side? If so, what was the solution for lowering the driverside?
Nice car!
Nice car!
[QUOTE]Originally posted by Liemoanh
[B]Where you having any problems with the driverside canister being higher than the passanger side? If so, what was the solution for lowering the driverside?
Okay, I just checked the spacing for you. It is very difficult to measure with a metal tape measure, but they are within 1/8" of each other...close enough for me .
