right rear wheel is tilted on MY05
T.T i just bought 05 gpw/tan
but right side of rear wheel is tilted....
upper part of wheel is pushed inward
does every car have that problem? or is it just my car?
service dept. said the car is in perfect condition... but i don't know
why it's tilted...
and they also stated it as same as i did....
please help me out~
why it's tilted...
please help me out~
Originally Posted by jihoonoi,Mar 21 2005, 11:15 PM
left is ok but only right one does that...
is it normal?
is it normal?
I don't know the factory alignment specs, but I'm assuming it calls for some negative camber in the rear -- perhaps -1.0.
Perhaps your alignment is off?
i think i need to take it to service dept. again...
i noticed the alignment of the tires are off... while i was driving
today..
when i set my steering wheel in center, the car goes left... it won't
stay still.... hmm... thank you jawknee~
today..
the rear wheels are supposed to tilt inwards as you described. If your car is pulling to one side, I suggest checking your tire pressures first before you start spending money on alignments.
Originally Posted by TubeDriver,Mar 22 2005, 07:05 AM
This is really simple. If one of your rear tires has *visually* different camber (on a flat surface with identical tire pressure) there is a huge problem with your alignment. End of story.
