revving too high
Old 07-31-2001, 12:39 PM
S2000PILOT's Avatar
Default revving too high
I raced a Gs400 last night and i accidently reved past 9,000 rpm. I only have 1100 miles on my S2000. Does anyone know if I caused any damage to my engine? Everything seems fine but im still kinda worried. Has anyone done this before? Well, I beat the GS400 but I couldnt beat him in first gear. We ran 3 times and each time he beat me in pick up but I past him in 2nd gear. Well that was fun!
Old 07-31-2001, 12:47 PM
layton's Avatar
S2K has a rev-limiter It will just bounce off of it after 9200 rpm. I've personally hit the limiter a few times and there has not been any ill effects yet. I'm sure its not good to be hitting it in every gear, but if a kill is on the line I say go fot it.....
Old 07-31-2001, 02:04 PM
Schatten's Avatar
Make sure you know where your rev limiter is - just go out, make sure its been warmed up for a while, and in first, just nail it, and don't shift. You aren't going to break anything. Actually you will only if you misshift- say from second to third, but hitting first instead with the revs all the way up. That will indeed bend some valves as I've witnessed and has happened to a few others before. But its nothing to worry about. But seriously, go hit the rev limiter, and watch it bouce in the red for a few seconds.
Old 07-31-2001, 02:26 PM
Utah S2K's Avatar
Posters are correct no damage done...this is the function of the rev-limiter. But we should also point out that rule 1 noted does not apply if you red line a downshift. Do this and you'll be seeing the dealer in most cases (i.e. bent valves).
Old 07-31-2001, 02:31 PM
golfnut311's Avatar
I've hit red line many times due to not looking at the tach but the road instead (probably a good thing?) It always ticks me off when the car lurches as the rev limiter kicks in, but I alwasy shift to the next gear and just take off.
So far, I have 5800+ miles on the car and no noticible damage to the engine.
However, I agree with UtahS2K that red lining in a downshift might/can cause damage. I always look at the speed before I downshift. I know what red line is in 1st, 2nd and 3rd. I don't have a need (right now) to know what red line is in 4th as I have only hit 120 in 4th and not been close to red line. I'm not sure I have the guts to find out either.
Anyway, have fun and drive her the way she was designed to be driven.
Old 07-31-2001, 02:49 PM
mjcohen's Avatar
[QUOTE]Originally posted by golfnut311
[B]I don't have a need (right now) to know what red line is in 4th as I have only hit 120 in 4th and not been close to red line.
Old 07-31-2001, 03:32 PM
Jay Li's Avatar
I've actually hit 92 in 3rd without bouncing off the rev limiter.
Old 07-31-2001, 04:51 PM
y2ks2k's Avatar
I spent 100,000 miles bouncing off the 8,250 RPM rev limiter of my del Sol VTEC (10.X:1 Compression). Half of my accelerations I bounced off of. Not a single problem with the engine (sold it needing a clutch though)....
Old 07-31-2001, 06:16 PM
goul's Avatar
Ive hit rev limiter in 4th gear many times , my s2k has done 3500km and ive had no ill effects apart from a little loss of oil , drive it hard thats what it is meant for i was doing 190km p/h when i had to put it into 5th
Old 07-31-2001, 08:01 PM
Barry in Wyoming's Avatar
I never knew it until I bought my S2000, but my '92 Accord and my '93 Prelude VTEC also have rev limiters.
Quick Reply: revving too high
