Revving high in 1st
Old 12-01-2005 | 06:19 AM
billmesh's Avatar
It's all about how you work the clutch... I have a 96 Altima which has significantly less power than the S2k and I barely rev it above idle (1500 revs max) to get it going.
Old 12-01-2005 | 06:46 AM
pushin9's Avatar
Dump the clutch as soon as you hit the rev limiter
Be sure to have a friend video tape this so we can watch too
Old 12-01-2005 | 07:04 AM
Intrepid175's Avatar
I've found that 1500 rpms works well in most situations. If you're in traffic, sometimes they haul a** and sometimes they creep along. When in creep mode, 1200 rpms works well too. It's just enough to insure that you probably won't stall it but won't have you running up the backside of the car in front of you either.
There's also a certain technique in feathering the throttle in as you're feathering the clutch out that goes a long way toward "not" killing the engine. All it is, is practice!
FWIW!
Drive Safe,
Steve R.
Old 12-01-2005 | 07:11 AM
Triple-H's Avatar
The lowest rpms I can get away with, basically the idle speed. Once the clutch has come all the way out and the system is completely engaged then I stand on the gas. For me this car is not for stop light wars so I'm real easy on the clutch.
For stop light wars I have the truck, and for that you have to be careful to NOT step on the gas too hard...
Old 12-01-2005 | 07:22 AM
Silver9k's Avatar
ya normally I don't get above 2000 from a light...at times I'll take it to 4000 when I want to have fun...but the majority of the time I'm easy on it out of the box...then I get on it afterwards
StatixNWH
02-16-2007 09:53 AM
vojm17
09-23-2006 10:30 AM
Y2K1S2K
06-26-2003 04:10 AM
S2Kay
12-20-2002 09:59 AM
fg23knight
04-23-2002 05:58 PM
Quick Reply: Revving high in 1st
