Retro-fit is POSSIBLE!
#31
Originally posted by OneQuickS2K
are they replacing the soft top only or the whole soft top + the frames?
could u ask them if u only have a 02 soft top would it fit the '00 frame? (assume u have the defroster kit wiring)
Thus no, the soft top for the plastic window CANNOT be fitted with the 02 glass window. You must change the soft top, AND frames in order to fit the glass. Otherwise, the glass rear window will break if you force fit it with the 01 frame.
#33
Once I get all the details back from the repair shop, I will let you know. The parts guy said that the 2002 top comes with the window for about the same price as the 2001 top + the plastic window. They had to order a retro-fit kit to make it all work.
I will probably not know the exact breakdown, but I wil try to find out once they are done. Hopefully I will get the car back by the end of next week.
#35
[QUOTE]Originally posted by eimea
[B]I just talked to the dealership, they had to make some minor modifications to the frame, but everything went well....
#36
I did not have to purchase a 2002 frame. They were able to replace the top on my MY01 frame with a 2002 top and glass back window with minor modification to the existing frame.
#39
I have a hard top installed. I wonder if the cost of new soft top would be reduced because the rear defrost switch and cord assembly is already installed in my car?
