Resetting Ecu
There's an easier way to do so. Remove a fuse from the box under the driver's dash. Which fuse? Do another search and you'll find it. I don't remember which one at the moment, so I can't say.
Although it will turn off the check engine light (just temporarily if conditions are not changed) it forces the ecu to relearn all fuel trim. I will not do it as it screws with the idle and low speed response. I use an OBD tool to reset CEL conditions, instead of living with idle problem for the next twenty trips.
Resetting ECU:
1. Remove the third fuse down from the second column (No. 25 Backup 7.5 A Fuse)
2. Wait for 60 secs and replace the fuse (make sure to note the orientation)
3. Turn on the car (with all electrical items turned off & throttle fully closed) and let it idle for 5-6mins (Idle learn process)
