Replace Windshield with Hardtop Installed?
Old 10-19-2015 | 05:56 PM
MikeekiM's Avatar
Default Replace Windshield with Hardtop Installed?
My windshield needs replacing (it's cracked)... I have an OEM hardtop installed with Izzy style brackets...so removing the hardtop is a bit of a PITA...
I am assuming that the windshield can be replaced with the hardtop installed... Can anyone confirm?
Old 10-19-2015 | 06:22 PM
8.5kallday's Avatar
Long story but Ive had my windshield replaced twice in the past 3 months and you'll be fine. I have a hardtop as well but top up,down,or hardtop is irrelevant for a windshield replacement. I only recommend to stick with oem eventhough its more money due to my shit experience with an aftermarket window recently..
Old 10-21-2015 | 07:50 AM
B serious's Avatar
You shouldn't need to....but removing 4 screws is a PITA? It probably took more time to make this post...
Old 10-21-2015 | 08:39 AM
RTZX9R's Avatar
You obviously don't has a HT with Izzy's brackets. Its more than 4 bolts, let alone alignment when putting it back on. Lot more required vs OEM latch system.
Old 10-21-2015 | 09:08 AM
MikeekiM's Avatar
While the process is not super complex (I'll give you that)... I stand by my PITA statement...
With the one piece Izzy Bracket, I have to take apart the interior panels on both sides (door sills, back/side panel) to get to the bolts, then carefully lift off the roof and put it somewhere safe (in a crowded garage)... Then I gotta do it all over again to put the roof back on...
Not complex academically...but still counts as a PITA in my book...
myflys2k
04-05-2017 10:06 AM
daher2323
08-24-2015 04:55 PM
macr88
Interior
03-17-2010 09:56 AM
bigfish
07-07-2002 11:06 PM
Quick Reply: Replace Windshield with Hardtop Installed?
