rear end
Old 09-10-2001 | 02:00 PM
Eze8199's Avatar
Default rear end
What do people mean when someone says that they got a new rear end? I assume that it has something to do with the transmission, but i may be wrong. Any info would be greatly appreciated. Thanks
Old 09-10-2001 | 02:08 PM
Sev's Avatar
Sev
Rear end, if speaking about drivetrain is the differential unit.
Old 09-10-2001 | 02:27 PM
Eze8199's Avatar
so could you possibly put some other cars, that has a strong differential, in the s2000? Without having to change the whole drivetrain?
Old 09-10-2001 | 02:41 PM
Sev's Avatar
Sev
[QUOTE]Originally posted by Eze8199
[B]so could you possibly put some other cars, that has a strong differential, in the s2000?
Old 09-10-2001 | 03:14 PM
LewKeim's Avatar
I've not read any threads about using some other cars Diff.
Is that because S2000 is that unique?
Old 09-10-2001 | 04:09 PM
Eze8199's Avatar
what cars rear end would you recommend to try and put in the s2000? Could you put a corvette one or a supra one? or just some other car that is really tough and can take abuse.
Old 09-10-2001 | 05:07 PM
Eze8199's Avatar
top
Old 09-10-2001 | 07:27 PM
Garyj's Avatar
[QUOTE]Originally posted by Eze8199 [B]what cars rear end would you recommend to try and put in the s2000?
Old 09-10-2001 | 07:43 PM
Sev's Avatar
Sev
The problem we have with our rear ends braking is not really because of the amount of torque, it is because of the interval the rear-end has to travel in order to make the wheels spin.
On typical muscle cars, you have to go from 0 to about 10 mph to get the tires spinning, on ours, we have to go from 0 to about 30 mph to make the tires spin. This puts a whole lot of stress on the rear end as it has to get moving reaal fast. Most street rear-ends should not fair any better then our own on our car, the input that the differential reacieves from the driveshaft at 6500 RPM on a first gear clutch drop is about (6500/3.13)/1.16= 1790 RPMs !!!!!
Combine this with a heavy back, sticky rear tires and crappy clutch that has to be dropped and you got yourself a problem with most differentials out there.
Things are not as simple as they seem sometimes.
surfer_crx
08-21-2015 09:33 AM
TerminatioN
03-17-2011 09:33 AM
APchassied
12-02-2002 06:59 PM
muppet
10-29-2001 10:18 AM
jschmidt
06-08-2001 05:33 AM
Quick Reply: rear end
