reached fuel cutoff
Old 05-08-2005 | 05:55 PM
ayS's Avatar
ayS
Default reached fuel cutoff
sounds like a paranoid question, BUT i guess i have to ask. i accidentally hit fuel cutoff the other day accidently. does this damage anything? or does fuel cut off protect it from anything bad happening? thanks gals/guys.
Old 05-08-2005 | 06:09 PM
Intrepid175's Avatar
Hi ayS,
It's a common question and the answer is no. The S2000 revs so quickly (as you've obviously found out! ), especially once it's in VTEC and in the lower gears, that it's not uncommon to bump the rev limiter from time to time, especially for those who are relatively new to the car. That's probably the main reason that Honda programmed it that way in the first place. It protects the engine.
Now, having said that, I wouldn't recommend making a habit of it!
Drive Safe,
Steve R.
Old 05-08-2005 | 07:34 PM
Mr. Francesco's Avatar
just don't make a habbit out of it...
you also have a rev cut for the temperature...make sure the cars always warmed up
Old 05-08-2005 | 10:15 PM
Silver_S2000's Avatar
^ Yep...found that out the 1st time i took my s on a spirited cold run with a cold engine (I freaked out wondering what the it was)
As for the rev limiter...it's there for a reason...Dont do it often, but dont stress too much about it when it happens.
Old 05-09-2005 | 07:39 PM
ayS's Avatar
ayS
thank you everyone for your responses i feel much better!!
Old 05-10-2005 | 01:25 AM
^ Yep
macbook s2k
03-02-2021 01:33 PM
s2000Junky
09-24-2008 12:09 PM
smikee
04-22-2005 05:52 AM
Qwik 1
11-11-2004 06:44 PM
whitelude
04-02-2004 06:53 PM
Quick Reply: reached fuel cutoff
