Rattle from rear of interior
Old 10-26-2024 | 09:43 AM
CK9887's Avatar
Default Rattle from rear of interior
2005, I have a rattle/tapping noise which sounds like it’s coming from behind the seats. It’s definitely coming from the interior and not a mechanical/driveline issue.
I’ve ruled out the common culprits (passenger seatbelt rattle, loose spare tire, roll hoops hitting the convertible glass). Access is difficult but I’ve felt around back there and everything is tight. Not sure if the noise is actually from something in the convertible top/glass or something from the void space behind the seats. Also, top is original and so is the back glass.
Any ideas? I’m stumped
Old 10-26-2024 | 01:35 PM
Car Analogy's Avatar
Top not original? During replace, have to drill out rivets. Sometimes old ones get stuck inside top frame tube, rattle around.
Old 10-26-2024 | 02:10 PM
CK9887's Avatar
Top is original and so is the glass. Also, car is 100% stock
Old Yesterday | 12:06 AM
BobLee's Avatar
Had a issue with sound coming behind my driver seat so i took my car apart to find a made in japan screwdriver that was floating around.
windhund116 (Today)
Old Today | 04:51 AM
Nandska's Avatar
the accessory power plug?
Old Today | 06:38 AM
CK9887's Avatar
ive ruled out the defroster plug/wire but where is the accessory power plug ?
Old Today | 07:31 AM
Nandska's Avatar
it's just the 12v plug. under the glove box. Fairly easy to tighten. But not sure if that could be the issue.
Old Today | 08:07 AM
CK9887's Avatar
The noise is definitely further back than that, behind our heads
The following 2 users liked this post by CK9887:
Nandska (Today), windhund116 (Today)
Old Today | 08:09 AM
windhund116's Avatar
Crazy! An authentic JDM screwdriver! Maybe straight off the assembly line. I hope you kept it.
BobLee (Today)
Old Today | 08:10 AM
Originally Posted by CK9887
The noise is definitely further back than than, behind our heads
Have you recently removed the spare tire? Maybe the hold-down is loose?
Quick Reply: Rattle from rear of interior
