Rats are eating an electrical casing
I'm looking for suggestions:
- In 2002, rats ate through the main wiring harness of my MY00 S2000 causing about $700 damage. I was living in San Francisco and had a shared garage.
- This week, I noticed it is happening again to the same car and in the same place as was repaired before. I now live in Oakland, CA (house) and recently discovered a couple rats have moved into my garage. I'm working on ridding myself of the rats, I've got one of those sonic thingies that make a high-frequency squeal, and I'm putting moth-ball cakes under the hood. All this is a mahor hassle since I drive the car every day. I also have re-wrapped the casing that has been chewed with two layers of new plastic casing. But I still find the occassional dropping under the hood.
Does anyone have any suggestions on this? Does anyone know why rats seem to have an affinity for my S2K?
My garage and house are clean - but CA homes aren't exactly sealed like East Coast homes, so I suspect I'll always have the possibility of them entering my garage, even if I get rid of these fellas.
My trap of choice is the Rat Zapper 2000 - worked great in SF. Just set it up in Oakland.
Anyone else have this issue?
Thanks!
Thanks!
rotf, yes the cat will handle them. Just make sure it's not a poosay cat like one of mine.
As for what to do, have you found out how they got in the garage? It's got to be something relatively obvious. They don't burrow and they don't climb.
Also, I know it's lame but try not to use anything lethal, I would suspect that this should work, is it the same one you got?
http://www.pestrepellerultimate.com/
