Questions about S2000 maintenance.
i am actually looking for a S2000.
i have a few questions about its maintenance. please help me
what's the average mileage to change transmission fluid?
every 15000 mile requires to change air cleaner ?
what's the mileage to change timing belt & water pump?
What is rear differential fluid?
what's the average lifetime of s2000's clutch?
thx.plz help me if u know any of them.
Try the "Under the Hood" section. I'm sure that someone over there can answer the question quickly. I just don't have that information on hand. However, the clutch life really depends on the driver. I have owned 2 S2000's and have never replaced a cutch. Other people can go through a clutch in 40,000 miles.
what's the average mileage to change transmission fluid? I just did mine at 27k
every 15000 mile requires to change air cleaner ? I change mine every 3 oil changes
what's the mileage to change timing belt & water pump? the S has a timing chain and as for the water pump whenever it quits
What is rear differential fluid? A fluid that coats and protects the gears in the diff
what's the average lifetime of s2000's clutch? depends on how you drive the car. there is no exact answer to this.
Hope this helps
Originally Posted by krosfyah01,May 21 2008, 05:12 PM
Since were on topic about maintenance what kinda rear diff. do you guys use/recommend?
Many (like myself) like Mobil1 75w90 Gear Oil. It is available on the shelf at most Autozones/Kragen/Checker/Etc @ about $10. It is well proven and I like the fact that I can get it just about anywhere. I just don't like having to order fluids.
Some (with Forced Induction) like Lubrication Engineers LE 6015 - formerly LE 607. It is a bit heavier duty and a straight 90w. Not recommended for cold climates.
There are some others, like Redline 75w90 or Royal Purple but they are used less frequently. Either way you'll want to get a hand pump (like a soft-soap pump) from the parts store that attaches to the bottle. Our diff and tranny fill bolts are on the side of the case and difficult to fill without these handy an dinexpensive pumps.
Service interval in the owner's manual under the "severe schedule" is every 15k miles.
-Hockey
"i am actually looking for a S2000.
what's the average mileage to change transmission fluid? 30k
every 15000 mile requires to change air cleaner ? Yes for an OEM filter.
what's the mileage to change timing belt & water pump? We have a timing chain and you don't change it unless you have the motor cracked open and doing other work. Water pump is not on any service schedule. Replace it when it goes out.
What is rear differential fluid? See above post
what's the average lifetime of s2000's clutch? Subjective. Anywhere form 30k to over 100k. Depends on the driver and conditions under which the car is driven (track car/weekend cruiser).
thx.plz help me if u know any of them."
All of my service interval replies are from the owner's manual under the "severe schedule".
-Hockey
-Hockey
