Question to those knowledgeable with Tein RA's.
"if you drop on tein RA's more than .5" you start riding on the bumpstops."
i read this somewhere on this site. the same person also said the best handling is gained by using the setup provided by tein initially.
in any case, if you lower the tein ra as much as it will go, you loose damper travel. the rear can only be lowered as much as .9" if i remember correctly as well.
