programming key fob help
Hey guys so I've never had a key fob on my s since I've had it, and I ordered a used oem one on eBay and I just got it and tried programming it but no luck, I tried the instructions I've found on here by searching but it doesn't work I have a MY00 can someone post instruction for me that are verified to work? Also did I even order the correct remote? Fcc id-A269ZUA101 REF NO. HFR-610 serial number w8701327356a thanks!
I bought a second remote fob, as I only had one when I bought my S. I followed the seller's instructions, but couldn't get both my new fob and the old one to work at the same time. I ended up calling their tech help line and we walked through the process a dozen times.
Try the programming with the driver's door open and closed to see if that makes a difference. It did for mine. when we got done with a successful job, I recommended a re-wording of their instructions to make it clearer. I believe you have to follow the repeat key on, hit button and repeat, procedure for a total of four (4) times.
lopez14
09-20-2012 10:10 AM
