problem with corner lights
After I installed ricks diffusers, when i lock my car via remote.. the side lights and the front diffuser lights dont work.. when i have my turn signal or my hazards on they work.. they also dont work when the headlights are on.. any advice?
Thats how they function. The fender light is for the turn signal and not for running lights.
There are 2 bulbs, 1 for "parking lights" and 1 for turn signals. When you click the remote to lock the car only the bottom "parking lights" should flash.
the tail lights blink, the sides and front do not.. it only start after the diffuser install, and none of the lights blew.. is there a seperate fuse for this function?
I would suggest that in the process of taking apart your headlights for the diffuser clearing, you didn't plug the park light wiring harnesses back in or you plugged them in wrong or didn't plug them in solid enough. There is also a very slight chance that in the same process, both the park light bulbs took a crap. This has been known to happen.
