Pressing the "Start Engine" button twice
Just curious: Did anyone accidently press the start button while the engine's already running?
Does the starter grind? Or is it smart enough to ignore the input?
As long as you arent holding down the clutch (why you would be depressing the clutch and pressing the button after its started I do not know) it will not grind. - press it all you want.
I did this before by accident when I first got my car
If the clutch isn't being pressed nothing happens but if the clutch is pressed it will grind just like if you were to turn the key on a car that was already started
Originally Posted by Ks320,May 12 2006, 02:28 PM
Dang ... I was hoping that the starter is smart enough not to grind ...
