Pre-muffler cut off
I had the resonator removed from my MY02. It doesn't sound raspy at all, it sounds a little louder, no drone whatsoever though. I recommend it, as do 95% of the other people who have done it. Do a search and you'll see a lot of info on this.
Some people have reported a 1-2 HP gain on the dyno.
Markk
Markk
I removed the resonator on my '06 S2K because I didn't like the "raspy" sound at mid-range RPMs, and I also figured it was a quick and easily reversible way to see if I could get a little "deeper" sound out of the stock exhaust system.
The exhaust sound without the resonator inside (and outside) of the car did achieve the desired effect. The raspiness is gone and the exhaust sounds a little bit deeper without any drone... I would do it again in a heartbeat!!! The S2Ks exhaust sound without the resonator is NOT loud, it is just a little bit deeper.
I'm sure there are a few well-intentioned and knowledagble folks on this board who will disagree with this simple mod; however, IT WORKS FOR ME, and consequently I'm done looking at any aftermarket exhaust systems. Any competent muffler shop can remove the resonator and stick in piece of straight pipe for $30-40. Make sure the resonator is cool to the touch before you stick it in your trunk and take it home (just in case some day you want to reverse the mod or sell the car as 100% stock).
As far as as I can see the only performance gains will be because of the ~7-8 lbs. of resonator that you aren't hauling around anymore.
If you cut off the resonator be sure to keep the Helmholtz tube in place (capped off pipe stub that sticks out sideways from the exhaust pipe) "because it is supposed to help reduce exhaust booming at certain frequencies."
ron
i did this a few months ago....liked the sound it produced
then i got a j's racing testpipe, and combining that with the resonatorectomy produced the crapiest sounding s2k ever, lol
i then bought a spugen single....and after 10 mins on the car, i sold it, way way too loud
then i got 2 magnaflow oval mufflers, had a catback system made @ "Performance Custom Exhaust" on long island, they make alot of exhausts for muscle cars, hot rods, that sort of thing....well, first they did it with just piping and the mufflers, and it sounded like total shit
so i had them put the resontator back in, w/o the helmholtz thing...and the exhausts sounds great
my buddy mark says that u cannot distinguish a difference in sound between my exhaust and our friend Sam's comptech (both have testpipes)
