Power dip between 2k -3k RPM?
I noticed there to be a slight power dip (or hesitation) when I floor the car between 2-3K rpm (I know I know, can't constantly keep it above 6K ). At first it was in second gear but I quickly realized it was there in first and third gear. Therefore, I can only conclude it is a characteristic of the F22C1 engine. I owned an F20C before and never noticed this behaviour.
I know certain Honda motors have strange power dips (i.e. RSX Type S).
I also have an K&N intake which is yet to be installed. I wonder if this will remove the power dip?
Originally Posted by RedCelica,Nov 4 2010, 08:41 AM
It's the drive by wire system
If the clutch is fully engaged, then the flywheel and engine are both spinning at road speed. I dont think it's the flyhweel. If he was going from 1st to 2nd and felt this I would concur. Hey, I could be wrong though.
04 here. Yes, mine does it. But any time it happens, my drving behavior could be considered "lugging" the engine, so I simply avoid high-load, low rpm.
Every Honda I've ever owned has had this characteristic in some form.
Originally Posted by Mike21,Nov 4 2010, 08:02 AM
Why would you floor it at 2000rpm? Why would you ever be at 2000rpm in any gear besides 1st?
