Plastic window
Plastic window
Any of you owners 00-01, by any chance are there any products you use to protect the plastic not from the sun but from humidity. I already have maguires for the plastic care but every morning its soo humid that when it dries up, you see all the water spots. Is there any type product I can use to prevent that. Thanks
Interesting I have never seen this question asked before...
Is the humidity on the inside or outside of the window? If its on the outside you may try parking your car the other direction in your parking spot. This may allow the condensation to gather on your windshield instead.
Have you tried rain-x?
If it's on the inside this is a bit more tricky. You may have some dampness inside the car that you need to let dry over a few days. But in FL this seems unlikely. Most Scuba stores will offer a variety of balms that help to prevent condensation from gathering, you could try something like that.
I was thinking about rainx but wasnt sure if you can use for plastic.. its on the outside.. my front glass, and side mirrors also get the condensation on the outside mostly every morning.. The front i dont care about cause of the wipers but the plastic I cant do anything about, the only thing that helps is when i start driving little water drops start coming off the top which start making the top more visible since the water drops are moving to the back of the car since imgoing faster.
