Passing inspection with test pipe?
Old 04-19-2006, 10:49 AM
Dolemike's Avatar
Default Passing inspection with test pipe?
Well, have the test pipe installed along with the mechanical o2 simulator, no CEL to boot. Aside from wondering if the inspector is anal retentive and wants to look under the car (visual inspection) should I pass?
Old 04-19-2006, 10:52 AM
S2kracka's Avatar
Probably not Give is a try though, see what happens.
Old 04-19-2006, 11:01 AM
Wisconsin S2k's Avatar
as long as there is no visual inspection and no cel, you will pass. most states do not run ODBII cars on the "dyno" rollers anymore. they just hook up to the ODBII unit and check to make sure there are no emissions problems (which would be indicated to you via a CEL)
also, this is not a vehicle problem, so moving to S2000talk
Old 04-19-2006, 11:17 AM
vtec9's Avatar
inspection or emissions test? don't know about other states, but in CT these are completely different. They will not check for a cat during emissions, but for inspection they would put the car on a lift specifically to check for a CAT.
Old 04-19-2006, 12:29 PM
Dolemike's Avatar
emissions test
Old 04-19-2006, 01:48 PM
vtec9's Avatar
can the car even pass emissions with a test pipe? That would be my 1st question Id like to know
Old 04-19-2006, 01:57 PM
OyATL's Avatar
I gutted my stock cat and did the mechanical o2 sensor mod. Works like a charm. No more hassle of having to change it out every year.
Old 04-19-2006, 01:59 PM
aronparsons's Avatar
Isn't removing a catalytic converter a major offense in places like CA? I believe they can hit you with a big fine IIRC from a few years back.
Old 04-19-2006, 02:00 PM
Nick32's Avatar
every time ive ever been to e-check.. or the emmissions place they have always had a mirror thing on a pole.. and they look under my car for the cat..
just get a heat shield and put it over your test pipe... they wont be able to tell the differance.
Old 04-19-2006, 03:42 PM
04RioS2k's Avatar
or get the t1r testpipe with the cat cover bracket, I love mine....
Quick Reply: Passing inspection with test pipe?
