PAINTING s2000 wheels
Old 06-06-2007, 08:22 AM
JPRICE!'s Avatar
Default PAINTING s2000 wheels
sup i wanna paint my s2k wheels black wat kind of paint would be suggested, i dont want it flaking off when i wash it..
i want it to look like this
i painted my friends gixxer flat black with chalk board paint...yes chalk board paint and it came out great im wondering if i can use that on the wheels...
another pic..
Old 06-06-2007, 08:56 AM
Triple-H's Avatar
Paint is not the way to go, powdercoating however is.
Old 06-06-2007, 08:59 AM
blackout's Avatar
paint works but needs to be touchedup when you get new tires. My wheels are painted and only the lips were slightly scuffed from new tires being mounted. just my .02
Old 06-06-2007, 07:42 PM
ZeroPsi's Avatar
Why don't you ask the guy whose ride that is... It so happens to be a local's ride and I know he used Duplicolor wheel paint, available at most auto parts store.
Although the results from a can is good enough for some, I will agree with the above poster about powdercoating vs painting as well, much better durability and over all look.
Old 06-06-2007, 10:12 PM
ian05s2k's Avatar
i would agree that powdercoating is a better option, and would reccomend that over painting them.
Old 06-06-2007, 10:18 PM
iam7head's Avatar
yes and no, most people just wing it with the spray can and it comes out nasty, but give a skilled diyer/painter a rattle can and you cannot even tell how's is it done. it's all about prep work and proper stages.
clean
stripe
sand
fill(if needed)
clean
prep rag
primer
enamel paint
wet sand
clear coat
wet sand(if need)
it's all about the detail, most of the average diyer will skip some stage and the rest of us assume rattle can is crappy, etc. for example the average diyer will not sand down the perfectly shiny oem finish, a perfectly smooth finish has little mechanical adhesion for the paint. The different between a primer and a self etching primer, etc
one thing about powdercoating is that it COULD weaken the structure of the wheels, there's been cracked/destroyed wheels and upon inspection from the MFG, it turns out that the powder coating process was to blame.
Old 06-06-2007, 11:10 PM
jzz30's Avatar
the curing temp of powedercoatings does reach typical aging temps of aluminum. thus changing its properties
Old 06-07-2007, 06:02 AM
vtec9's Avatar
any good PC shop will know how hot you can bake forged aluminum wheels. you won't have a problem unless you take it to some idiot.
Old 06-07-2007, 07:53 AM
chairmnofthboard's Avatar
I looked into it. Powder coated heats the wheels to 400 degrees. Too hot IMO, why not just paint them right, the factory wheels are painted.
Old 06-07-2007, 08:01 AM
pdexta's Avatar
I painted mine with the dupli-color paint and was very happy with the results. They came out really nice I've gotten quite a few compliments on them. Realistically, if you've got $500 worth of tires mounted and balanced on your AP1 wheels you'll be able to sell them for $300-400. The wheels are basically worthless; it makes no sense to invest a couple hundred bucks to have the wheels powdercoated when you can paint them myself for $4.
Quick Reply: PAINTING s2000 wheels
