painting calipers
painting calipers
i want to paint my calipers red. is there anything special that i need or any specific brand that anyones used?
i painted mine with G2 caliper paint. it was like $35, and i put about 4 coats on each caliper. also, i dremeled the calipers to get a smoother surface. that took the most time (4 hours or so).
it would also help if your car jacked completely off the ground so you can work your way around all 4 corners, and then repeat for more coats.
also, you should think about getting some S2000 decals, they look sweet on the red calipers.
[QUOTE=S2-3456789-K,Sep 26 2007, 03:59 PM]i painted mine with G2 caliper paint. it was like $35, and i put about 4 coats on each caliper. also, i dremeled the calipers to get a smoother surface. that took the most time (4 hours or so).
www.vinzdecals.com, go to caliper decals, use the middle font on the right column.
FYI - that's where i bought mine.
https://www.s2ki.com/forums/index.php?showt...&#entry11197794
this guy has done the best job of any i've seen. good luck. i'm thinking about doing mine realllll soon!
