Owner's with Modifry Shift beeper///
For anyone that has the shift beeper installed and the mini siren... I was driving the other day and the siren just started going off and won't stop. No matter what I do, as soon as the key is turned on the siren is blasting not stop.
Any idea before I go deaf? I checked all connections, pulled the fuse, put it back in, no good.
Jason,
email modifry at bob@modifry.com
He was very responsive when I had a question about one of his products.
Doug
Doug
Since neither the main beeper nor the Valet mode siren are supposed ot be able to be set below 3000rpm, I'd guess that it's a problem with the beeper circuit board.
The sirens turn on when the circuit board provides a ground - the sirens are both attached to a 'hot' wire at all times. Is there a chance that there's a short to ground somewhere?
Modifry's always been very responsive - he just may be away for a few days. Hang in there - he'll get you sorted out.
JonasM
JonasM
he's always took care of me... i went through a lot with him trying to get my nitrous setup with his shift indicator... i even suspected shorting out a few of his boards and he's replaced them free of charge.
do you see anything loose or any wires that may have come undone?
Cool. I'm sure he will reply, I just wanted to check with you guys if it was a quick fix. It's 85 degrees and I want to drive!!
Everything looks find on the wires and ground. It's strange, I just messed with it and as soon as I slide the fuse back in and connect it, siren comes on full blast.
I do apprreciate the replies.
