Only Jacks stand in front of car during oil change
Old 11-17-2010, 08:36 PM
  #31
Ronss2k's Avatar
on the fumoto oil drain do you still have to change the washer?
Old 11-17-2010, 08:56 PM
  #32
Ronss2k's Avatar
do we need a adapter for the Fumoto Oil Drain Valve
Old 11-17-2010, 09:00 PM
  #33
obsess2k'ed's Avatar
I just ordered one today from JS2K.com. It comes with the washers and adapter:
http://www.js2k.com/index.php?main_page=pr...&products_id=13
Old 11-18-2010, 08:36 AM
  #34
gtg749m's Avatar
no need to change washer. and adapter is needed
Old 11-18-2010, 11:18 AM
  #35
Sponsor
Vendor - Starter Primary
JS2k.com's Avatar
Thanks! Hope you enjoy it!
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Old 11-19-2010, 12:24 PM
  #36
Greg W's Avatar
I too use the Fumoto oil drain valve on my '05 AP2 with stock intake. Very easy to drain and replace oil filter from above, even with big hands ad forearms. It takes a few minutes longer to drain, but makes the whole oil change process much quicker and easier. I highly recommend it.
Old 11-19-2010, 01:46 PM
  #37
hirev's Avatar
Rino Ramps .....safe and easy. somehow most of the oil makes it into the pan when i do my change, and it is clean upon starting the engine and rechecking. i am yet to fit my filter wrench on the oil filter, usually it is hand tight since i put it on in the first place. if need be i used a large pipe wrench to loosten the filer as i will not be using it again.
Old 11-19-2010, 01:59 PM
  #38
Former Sponsor
Moddiction's Avatar
Originally Posted by LMB2000,Nov 17 2010, 09:27 AM
+1
use the jack that comes with the car.... and forget about jack stands...
you only need the car high enough to put the pan under it and unscrew the plug.
Old 11-19-2010, 04:34 PM
  #39
edspecR's Avatar
[QUOTE=LMB2000,Nov 17 2010, 06:27 AM] +1
Old 11-19-2010, 04:41 PM
  #40
zzziippyyy's Avatar
:always: use a jack stand for safety when under the car,you can use the one jack stand method as discusse din this thread along with the jack but never EVER go under a vehicle with just a jack supporting it.
Quick Reply: Only Jacks stand in front of car during oil change
