oil question on new car
manual says change oil every 7500. extreme condition at 3750. both seems pretty high for me. also is that with regular oil? i really don't wnna use regular oil that long. second i know oil came with the car has additives. salesman told me change at 5000. i hear 3750. which one? i really don't wanna use oil that's all black. i rather spend more money and change oil before it gets really nasty.
I'm one who doesn't believe there were any "additives" put in the factory fill. It is high in "moly" but this is most likely due to the assembly lube that was used liberally during the manufacturing stage. If you are worried about losing this "additive" when you change out the oil too early, you can always put in a can of moly additive.
Black oil is merely a sign that your oil is working. If your oil never got dark, then you have to worry. Change the oil when YOUR interval comes up. Just keep adding oil if your engine uses a bit (the owner's manual also tells you what type of oil to use) and don't worry about it getting black. Black oil still works and protects.
Shoot, I'm confused as to whether or not I fall under severe or normal condition. At most, I'm stuck in stop and go traffic every now and then, but i also do a lot of driving in non congestion hours.
Read both lists of conditions. Pay particular attention to the "severe" list of conditions. If ANY one of those applies to you, you have your answer. Very few owners would fall under the "normal" schedule. I can think of one that might ................ A travelling salesman who drives long distances where the car is shut off very few times per tank of gas.
Originally Posted by berzerQer,Jul 31 2005, 11:03 AM
You're most likely in "severe" conditions so just change to synthetic at 3750 exactly like the manual says.
Originally Posted by oakfloor,Jul 31 2005, 04:16 PM
no synthetic untill 7.5k-10k miles!
*waits for someone to post that poorly scanned article "from honda" claiming that you shouldn't change to synthetic until 10K*
