oil life indicator on the dash
Old 07-07-2009, 12:37 AM
dn7309's Avatar
Default oil life indicator on the dash
do any of your guys use the oil life indicator as a reference to know when to change oil or, you just go by the 3000 miles rule?
Old 07-07-2009, 02:18 AM
Snowmoto125's Avatar
3k mile rule for me!
Old 07-07-2009, 03:33 AM
LittleBluePill's Avatar
I usually do around 50% which is around 3700-4200 miles.
Old 07-07-2009, 04:07 AM
JackS's Avatar
Using a synthetic the reminder plus a 6mo. self imposed rule works out to about half of the suggested life span of the oil. The SM suggests that the minder will show 0% between 6-7.5k depending on the type of driving you do and that the oil should be changed on a yearly basis if this milage is not met. 6 month or 6k seems very reasonable to me with a synthetic.
Old 07-07-2009, 04:11 AM
//steve\\'s Avatar
Yeah if you're using synthetic there is no need to be changing the oil every 3k miles unless of course you are tracking the car regularly then you should probably be checking on it more frequently. The last time I changed the oil in my s2k I went 6k miles on it.
Old 07-07-2009, 06:31 AM
shamoo's Avatar
I change it every 7000 or so miles on Mobile 1. About 50 or so miles prior to hitting the 7K mark, the oil life indicator will go on showing ~15%. By the time I get to changing it, it shows around 5% or 10%.
I daily drive my car, rarely Vtec/redline.
Old 07-07-2009, 10:31 AM
CalBear07's Avatar
I use the indicator. 3k is overkill, even if you are using dino oil, unless you are tracking.
Old 07-07-2009, 10:49 AM
ace123's Avatar
I use the indicator and synthetic.
Old 07-07-2009, 11:05 AM
s2k dre's Avatar
5K is good enough for regular oil! i change mine every 3k because it only cost me 20 bucks.
Old 07-07-2009, 11:18 AM
Sponsor
JS2k.com's Avatar
I try to use the 3000 miles rule, but it may be 4000 miles before I do it.
Just as an FYI, the Oil Life Indicator doesn't actually show your oil life, just a % based on miles.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Quick Reply: oil life indicator on the dash
