Oil level drop... still a problem?
After 26000 miles my level still drops significantly. I switched to Mobil 1 at about 8000 miles. Every oil change cycle a half to 2 quarts is needed to top off.
Anyone else with the same problem? Anyone care to guess why that is?
I guess the unusual cylinder wall material, the high rpm, and other factors combine to make this engine different when it comes to oil consumption. Mine used no oil in the first 20K miles but has started to consume oil since.. I can find no leaks but I am now (at 27K) adding a quart in the period between changes.. kinda worrisome as it is not the slow linear change in consumption I expected.
Originally posted by DarioManfretti
You might want to change back to regular oil, like Castrol GTX. Maybe it wasn't broken in completely at the 8K mark.
I've noticed my engine using a bit more oil since it passed 10,000 miles. Nothing extreme; I always add oil when I'm two "X"'s down, it just seems to happen faster now.
I'm currently at 10,800 miles and plan to go synthetic in a week or two.
