OEM Seats
OEM Seats
Hi,
I just got back from my lunch and was curious to see if the passanger side seat would directly fit onto the driver side. Would I have to switch rails or is it just a direct switch?
P.S., my driver seat is getting a little worn so I want to slow down it's process by swapping seats.
Any help is appreciated.
Thanks, David.
Thanks, David.
I swapped the bottom cushion with cover from the passenger side to the drivers side. It was a simple process. It was a direct fit. I didn't try the back due the seat belt loop.
I removed the seats from the car. The bottom cushions are attached to the frame with a couple of bolts. I can't remember if there is bolt per side or two. Remove the bolts and the cushions come right off. Switch sides and re-install the bolts. That's it.
Did it look funny having the worn one on the otherside?
can you post pics of the new passenger side? wanna see what that seat having a worn left bolster looks like
