OEM Lug Nuts
OEM Lug Nuts
I heard that it's not good to use OEM lug nuts on aftermarket wheels. I got a used set of work emotion xd-9, that didnt came with lug nuts, so im still using OEM lug nuts on these wheels. I need to change my lug nuts as soon as possible, does anyone know what kind of lug nuts I need to this set of wheels? Any help will be appreciated. Thanks
Lub1
Lub1
Any tuner lug will work fine. TONS of different ones to choose from. Search and you will find everything you need. If your unsure go to a and j websight as they carry a lot of them. You can easily find them on ebay for a lot cheaper as well.
If you take a look at the area where the lug would seat, you can determine if the OEM lugs (rounded) will work with your rims. There are usually rounded or tapered. You don't want to mix them up.
