Now my S really moves!
Additionally, over-inflating tires can lead to uneven wear (middle now goes first) , and the stock tires, while amazing, don't last all that long as is.
Hunter S. Thompson says: <edited for brevity>
"But the whale --- instead of cutting loose at the critical moment --had a tendency to dig in, which accounted for that sickening 'here we go' sensation. At first i Thought it was because ... the tires pumpted up to fifty pounds each, which alramed the attendant....It's not often that a man gets a chance to run terminal experiments on a virgin Cadillac with four brand-new $80 tires. For all I knew, that thing might start corrnering like a Lotus Elan." <-- Fear and Loathing in Las Vegas.
when you calculate heat inside the tire, that 37 will soon turn to 40 +/- 1-2 #'s. That is way too dangerous. I also run 30#'s and if you measure after a spirited run through the canyons, it will quickly reach 32-34 #'s. It is way too dangerous....
Do so at your own risk!
Drive Safe,
Steve R.
I only use 11psi in each tire because the air pump costs $0.50 and never lasts long enough to air them all up to 32psi. It'd be dumb to have 2 tires at 32psi and the other 2 at 10psi, but when that happens, I make sure the 2 tires with 32psi are on the driver's side to accommodate for my extra weight.
Only way to tell is to take it to an autocross (or setup your own road-course in an empty parking lot)..bring an air-compressor... and start dialing it up..
For me, runnign A032R's 225 front/255 rear R-Compound, I have to run 30psi rear, 35psi front to get balance right... otherwise I over/understeer badly..its actualyl quite sensitive...
Running the SAME PSI on front/rear (even on S02s) caused me to understeer in hard turns.
I run 35psi all around.
I have driven at triple digits and it seems fine.
But i wouldn't run any higher in case i hit the max psi rating and hit a pothole.
I think that would cost me more to replace two tires.
Plus too high of tire pressure makes it more of a bounce ride.
Strangely enough, I feel a little more confident with higher pressure because I can feel the road better. It is as if even though the traction may be less, I have a better sense of how close I am to the edge.
It is more bouncy, though, and you can really feel the road textures.
