Noise canceling head phones in the s2000
Good thread!
I booked marked the ETY plugs.
I recently installed aftermarket engine/trans/diff mounts, but purposely went with Spoon for minimum NVH, which isn't bad. For a 4-5 hour road trip I can easily imagine the slight increase in noise being fatiguing.
You don't want noise canceling headphones -- I never understood the concept of blasting your ear drums with more sound to cancel out existing sound... Sounds exhausting.
If you care about preserving your hearing -- and welcome to the club -- you need musicians earplugs.
I have personally been using these for years -- great top-down -- you can hear everything, but the ear-damaging decibels are lowered for your safety (makes road trips more enjoyable):
Etymotic Research ETY Plugs High Fidelity Earplugs; Standard Fit, Blue Tip, Polybag
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
And here are the technical/safety specs:
https://www.etymotic.com/downloads/d...n_brochure.pdf
HarryD (03-07-2018)
The noise cancelling function is designed to create an inverse pressure wave of the background noise in an attempt to nullify it. This counter action in effect reduces the pressure wave impacting the ear.
Right. Its how much your eardrum moves. No movement, no damage. You have one waveform of noise. You have another waveform of opposite direction. When they collide, they literally cancel each other out. It does indeed make the sound, and its energy, go away so it doesn't hit your ears.
Speakers can make noise, but they can also make quiet.
@Rpg I can only speak personally; main purpose was to be isolated from the bad NVH drones in general from the car tire/wind/exhaust drone (the big one). So adding an exhaust or other self inflicted noise generators persay isn't too much of a problem as the phones I have in particular gets rid of all bad NVH drone but keeps all the good sounds.
Awesome posts, thanks guys; peace of mind for NC users. It appears we're indeed cutting a lot of damaging noise to the ear drum any time you're in loud or annoying constants (wind, booming, generators, vacuum cleaners etc.)
From wanting to cut noise. Personally, my unit in particular allows me to hear everything necessary AND can hear different notes that the engine/exhaust produces to a significant degree since as mentioned the drone/boom is cut out but the rest of the progressive noises still available. That is what I was aiming for for and just wasn't sure if the magic was faux or real. Seems that it's real with the recent postings and readings. anyone else got some posts go for it.
I'll still be purchasing a set of ETY with my next amazon haul though, for various other purposes and testing.
I stand corrected -- I suppose I learned something new today about noise canceling headphones canceling out sound waves before they reach your ear.
https://ask.metafilter.com/283162/Ar...ing-my-hearing
Being somewhat of a luddite, I suppose I'd still prefer my musicians earplugs to cut off the damaging decibels (and just turn the stereo up higher while top down).
Well, there are some clear advantages to old school earplugs:
- Passive, not active. More reliable, no batteries to keep charged, nothing to break.
- Cheap. No fear of losing them, etc.
- They attenuate all sound, not just the recurring drone type. Will protect your ears better from short, sudden blasts that active noise cancelling don't. Downside is also blocks sounds you do want to hear. Horn, that dump truck barreling down on you, etc.
I’m most fascinated about the idea of your own exhaust being so loud that you have to protect yourself from it. The performance gains can’t be so great as to outweigh the inconvenience, no?
I do get the idea of wearing them on lob drives with the top down. That said I have never driven further than an hour away from home in my s2000.
Musicians ear plugs don't do that. You hear everything, just not at damaging sound levels. I can hear passengers talking, horns, road noise, etc. The loud stuff, however, is much reduced.
