NKG Platnium vs. Denso Iridium
Old 09-07-2005, 05:29 PM
143hawaii's Avatar
Originally Posted by vinnie's2k,Sep 6 2005, 07:28 PM
Ordered Brisk DOR 14 IR. Will let you guys know how the spark plugs perform once its arrived.
I saw the dynos on their page and all of their tech. Their theory sounds sound but I'd love to see or hear more from how they perform on a high compression/high revving engine. Let us know what you think
Old 09-08-2005, 02:21 AM
leester01's Avatar
Denso iridium is thinner then NGK iridium.Denso is size .4 tip NGK is .8 tip.The Denso's wear out quiker so you just have to change them more often.Spoon S2000 uses Denso and JGTC NSX uses NGK so go figure.
Old 08-26-2007, 06:23 AM
REV.Group's Avatar
NGK platniums OEM had recall from Honda switch to Denso
Old 08-26-2007, 10:20 AM
INDYMAC's Avatar
Interesting. Where did you find out about this recall? What was the reason for the recall? I just bought some NGK Laser Platinum #PFR7G-11S Stock #7772 (OEM) plugs from NAPA a couple of weeks ago, and they didn't mention a recall on them.
Old 08-26-2007, 10:48 AM
toofast4yalll's Avatar
When I went to test drive my S, it wouldn't start. I ended up having to test drive an '02 first while they changed the plugs in mine. They said they switched it from the OEM NGKs to Densos because people were having problems with the NGKs. FWIW I didn't buy from Honda, I got my car from the Toy Barn. They know their stuff and specialize in exotics.
Old 08-26-2007, 05:46 PM
ottokrat's Avatar
Also, you can check out the following NGK iridium plugs:
5068 IFR8H-11, and,
7746 IFR7G-11KS
The 7G is recommended by sparkplugs.com for S2K (06&07, didn't check other years). It claims "special firing end construction", has the right gap, and the same heat range as OEM.
I'm using the 8H (the 7G seems to be new or somehow I didn't find it before). It has the tapered ground, projected tip, and one heat range colder than stock. These appear to have the 0.6mm iridium electrode. (Other NGK iridiums have 0.7 and yet others 0.8... Don't know about hte 7Gs)
Both of these NGK's have iridium and platinum.
(The Densos have the 0.4mm center electrode.)
In the Denso there is the IK22 and the IK22G, which has a slight difference in base of the tip of the center electrode, and I think some recommend it for the S.
Old 08-27-2007, 04:59 AM
REV.Group's Avatar
I bought my car in 02 honda send me a recall notics through the mail and it was the campaign on spark plugs saying honda had a problem with the NGK so change mine over to Denso but then i changed it again to Denso Iridium with Okada Projects www.okadaprojects.com car response great willing to try the NGK iridium but haven't had the change to yet probley is like buying gas at that point Mobile or Shell
Old 08-27-2007, 07:59 AM
VAD
VAD's Avatar
I've searched and found no evidence of this. Please site your source.
Old 08-27-2007, 08:17 AM
00CivicSi's Avatar
Holy CRAP, that was a b!tch to read. I know it's the internet and all but a little punctuation goes a long way.
S2KMOB
02-10-2018 07:35 AM
brasil042239
02-03-2012 10:56 PM
eDiesel
09-19-2011 03:42 PM
Quoi?
08-12-2009 08:04 PM
Daygo S2k
04-09-2009 12:57 PM
Quick Reply: NKG Platnium vs. Denso Iridium
