need to re-clip roof when closing it?
Old 08-20-2008, 05:34 AM
sanjay's Avatar
Default need to re-clip roof when closing it?
just wondering....does the roof NEED to be reclipped when parking the car? at work or home (both underground parking) ...i tend to park roof open .... but if i run into a bank or something where i'll be gone more than 10 minutes and it's not underground i'd like to close it
do i need to lock the clips everytime it's closed if i'm going to reopen it the moment i get in?
Old 08-20-2008, 05:40 AM
daktruckie99's Avatar
No, quite often I'll leave it unclipped for short trips. Anything more than a couple hours I latch it down tight tho.
Old 08-20-2008, 06:41 AM
Incubus's Avatar
BE CAREFUL...I used to do this until I forgot to latch or lower the top. I just drove off and, well, something bent or snapped. The top never latched right after that.
Old 08-20-2008, 07:26 AM
boofer's Avatar
wow, you guys are LAZY. it takes a full 4 seconds to close both latches when you park. are you in that big of a hurry?
Old 08-20-2008, 07:39 AM
Well, if you get out of the car and are about to get back in, do you lock it even tho it only takes one click of the button?
Old 08-20-2008, 07:45 AM
Nickamsweet's Avatar
don't wanna be a dick, but i do lock it...even if i can see it and with mates in a car park...
i paranoid as hell
Old 08-20-2008, 07:47 AM
MikeyCB's Avatar
The reason I don't latch it every time (if raise the top for shade or in case of rain in the few minutes I'm inside) is that I don't want to wear out the latches. I've heard of peoples' latches no longer holding themselves up after repeated use and I don't want to hurt the mechanism.
It's not the time, the point is to avoid wearing a part out - in my case, at least.
Old 08-20-2008, 07:52 AM
Saki GT's Avatar
I don't latch it, if I even raise the top, if I'm just going in somewhere. Fyi, its also watertight as its been unlatched in the rain - no leaks.
Old 08-20-2008, 07:57 AM
3ngin33r1's Avatar
Oh my god, it's a car! Use it!
Latches wearing out... sure it's happened, one guys car just caught fire, maybe you shouldn't drive at all. Airplanes crash, so don't fly. Don't shave either, razors get dull with use and then you'll have to buy a new one.
GT_NFR's Avatar
I don't latch it if I know the top is going down the next time I drive it. However, I did forget to latch it one time but I realized it before I pulled out of the neighborhood. No damage done but I will def be more careful.
Quick Reply: need to re-clip roof when closing it?
