Need New Rear Tires...What's the Problem??
Old 12-08-2000 | 11:13 AM
Butcher99's Avatar
Been away from the group for a little while, but there seems to be quite a bit of heat about the OEM S02 and what they can be replaced with.
Can you guys please bring me up to date. Are the Potenza S02 the only replacement tire we should use? Does the S2k need a special S02? Is there a problem getting these tires????
Can somebody please just give me a quick update with what's going on please...
Many thanks
Old 12-08-2000 | 12:48 PM
Squeezer's Avatar
My understanding is that if you want to keep the handling, you have to go to a bridgestone tire dealer and ask for the correct size Honda OEM S02 Potenza's.
Old 12-08-2000 | 12:58 PM
STL's Avatar
STL
And supposedly if the tires are marked like: 225 50 R16 92W (rear) or 205 55 R16 89W (front)
then they are the correct (meaning Honda OEM version) Bridgestone S-02. These Honda OEM tires only come in two sizes (the 205 and 225).
It's been determined that a 225/50 Honda OEM S-02 on the stock 16" rims (that's 7.5" wide) has a wider contact patch than a 245/40 PolePosition S-02 on a 17" rim (that's 8.5" wide)!!
[This message has been edited by STL (edited December 08, 2000).]
Old 12-08-2000 | 08:18 PM
SkipX's Avatar
Has someone in this group ever take real measurements of these OEM vs. OTC PP's. I do not understand how a 205mm wide tire can be wider than a 245mm tire?
Old 12-08-2000 | 10:53 PM
S2WOOOW's Avatar
My tires measured 205 front and 235 rears, measured at wides part of tire, mounted on stock rims, 34 psi cold. I'm wondering if this is the proper way to measure a tire. Should it be measured unmounted?
[This message has been edited by S2WOOOW (edited December 08, 2000).]
NC s2k
10-13-2006 07:56 PM
newsguy
08-24-2004 04:56 AM
s9000
06-29-2004 12:02 PM
Red-S2k-00
09-08-2003 01:54 PM
VtecNE
02-13-2003 04:00 PM
