Need a little help from an 02 model owner
I posted the following in the electronics section as well, but thought I would add it here to cover all my bases. Thanks in advance and pardon the grammar errors I found as well as the lack of spacing that the board didnt like for some reason on the button descriptions.
I recently had my S2K vandalized. They cut open the soft top, got inside, pop'd the hood, and stole my headlights as well as the gear shift knob. Also, for some stupid reason, they pried off the S2000 symbol on the front left quarter panel.
Anyway, after getting the damage fixed(and after installing my new Clifford alarm system), I need someone to tell me how to set the time on the CD player. I didnt get a manual (yes I checked the hidden compartment). All I have is the little white tags that told me the alarm code to get the CD to turn back on. Here is a list of the buttons as well as what they are labeled:
FF Play/Prog. REW NR DISC- DISC+
1 2 3 4 5 6
On the right side are 2 buttons. The top one I think is the auto repeat(not looking at it right now). The second is labeled strange. It says something like A.SEL or something similar, and right above that etched above the button is the word "clock". However, I have tried so many different combinations of button pushing, that Im going insane hehe. I cant figure out how to set the time on the clock.
Thanks for any help in advance.
P.S. I was also under the impression that the cd player was only a single CD player so I was curious about the DISC - and DISC+ buttons since I couldnt figure out how to load a 2nd CD into the player, if indeed it did allow multiple CD's. I bought the car out of state and I am having a hell of a time getting anyone to send me the documentation, which I have asked for numerous times to no avail. I do love the car though. Here are some links I put on our web page.. Nothing fancy and no index, so you must make sure the file extensions are capitalized.
I had just washed the car the previous evening and took some pictures. The next morning, this is what I found
http://www.midland.edu/~pmcguire/top.JPG
http://www.midland.edu/~pmcguire/stickshift.JPG
http://www.midland.edu/~pmcguire/s2kemblem.JPG
http://www.midland.edu/~pmcguire/missingA.JPG
http://www.midland.edu/~pmcguire/missingB.JPG
1 2 3 4 5 6
Look under the 4 and 5 and you will see an H and a M. Hold the clock button and then push the corresponding buttons to change the hours and minutes. (I think those are the buttons, look close, you will see the symbols under the numbers)
It is a single disc player but you can add a honda CD changer that is controlled by the in dash unit.
Frenchie
08-16-2002 03:30 AM
